Leslie1925
- May 29, 2024
- 1
- 4
Craftsman rider. New ignition switch, battery, wiring harness and spark plugs. Turn the switch to on position and volt dial does not move. What should I look for next?
More details? Mower model? Engine brand and model? "Volt dial does not move"... what's it connected to?What should I look for next?
Does the harnes have a fuse installed?Craftsman rider. New ignition switch, battery, wiring harness and spark plugs. Turn the switch to on position and volt dial does not move. What should I look for next?
A month ago I took my Craftsman LT1000's battery off its wintertime battery maintainer, installed it. After 30 minutes of mowing tumbleweeds, it stalled because some got stuck in the deck. After removing those, I could not get the starter to crank. I investigated, checked out continuity on the ignition switch, finally realized the the relay for the starter was not getting enough voltage for the relay to deliver voltage to the starter itself.Craftsman rider. Turn the switch to on position and volt dial does not move. What should I look for next?
My mower model is 917-289700. Serial 031709B008030. Craftsman 24 HP, PYT9000. We have checked the safety connections under the seat and the clutch. Both are fine. When the key is turned to the on position, AMP meter does not move nor will it move in the start position. New ignition switch, new battery, new plugs and new wiring harness. Any thoughts on where to look next? Thanks.More details? Mower model? Engine brand and model? "Volt dial does not move"... what's it connected to?
