Could be several things. Safety switches, dirty carb and fuel tank, never checked valve clearance, vacuum leaks and low compression.I read a blog on this site stating Kohler engines have problems with voltage spikes frying the modules if there isn't a diode in the wire going to clutch. Could that be my problem since I just put the new clutch on? Keep in mind I do have spark and fuel and the engine cranks but doesn't start.
Won't be because valves never adjusted it has hydraulic lifters. You say it has spark so that should rule out the ign modules and safety switches.. Fuel shut off solenoid. Where is the fuel getting to. Try spraying gum out carb cleaner in the carb and see if it hits and runs for a few seconds. KISS did you inadvertently unplug something when you replaced the clutch.Could be several things. Safety switches, dirty carb and fuel tank, never checked valve clearance, vacuum leaks and low compression.
Not related but never cleaned the cooling fins and block or de-carbonized the cylinders, valves and heads.
