Won't start while hot after tilting...
sgkent
not sure where the repair is but the engine is flooding from being tilted. Fuel is running out of the carb into the cylinders. My only suggestion if you wish to continue on this path would be to put in a fuel shut off lever, and let the engine idle until it stumbles, then turn it off, clean it, put it back down, turn the fuel on and start it up again. Carb floats and bowls don't like high angles. Fuel can drain out thru jets and other passages.
