1947Ford8n
- Sep 8, 2026
- 3
1998 Briggs & Stratton engine model 12F702 on a D&R walk-behind mini brush hog. Bought it 2nd hand in May. Ran great until a week ago. It will start with a spray of starting fluid, but won't start or run on gasoline, so we know it's getting air and spark. I took apart the fuel tank, fuel lines, carburetor. All were clean, but I cleaned them again with carb cleaner and brake cleaner. Fuel flows freely from the tank to the carb. Carb inlet is clean, jet is clean (appears to be non-removable), float operates freely and the bowl fills naturally. I bought a genuine B&S carb rebuild kit and replaced the needle valve, gaskets. This carb has no choke, idle or mixture screws, no adjustments. It seems fuel is not getting past the carb. Any suggestions, outside of a "new" carb?
