At shutdown accidently pushed lever to choke backfired now it wont start, check fuse ok,
L lloydbarr Forum Newbie Joined Jul 12, 2017 Threads 1 Messages 1 Jul 12, 2017 / Wont Start Ariens modle 936083 42'' automatic #1 At shutdown accidently pushed lever to choke backfired now it wont start, check fuse ok,
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Jul 12, 2017 / Wont Start Ariens modle 936083 42'' automatic #2 Try a new spark plug If that does not work then pull the blower housing off then the flywheel retainer and check the flywheel key. Some times they can shear when the engine backfires and then the timing will be off.
