My craftsman ride on won't crank, I have fully recharged the battery, But when I turn on the ignition switch the amp meter doesn't even move at all and subsequently when I try to turn it over there is nothing not a sound made at all, The engine is free and moving, I have removed the upper cover and am able to turn the flywheel above the engine. The cut off switch under the seat appears to be fairly new and I placed a wire between the terminals there to make a complete circuit and still nothing. Any suggestions would be appreciated as I'm at a loss at the moment.
