Wisconsin Robin Snapper parts
upupandaway
On the carb fuel inlet, I think these are thread locked slash pressed in. So rotating yours sounds right. Mine as mentioned is at 5 O' clock.
Yes the fuel inlet size. Off the tank at the fuel cutoff, that valve outlet is tiny. I tried the usual mower size 1/4" hose. It contacted the larger barb area only, not the pipe on the carb fitting and cutoff valve. This fuel line is 1-2 sizes smaller than 1/4" hose. It's the same size as the carb vent line that runs off the top of the carb.
Oh... well i think find a brass adapter at either hardware, auto parts, or hobby store. I can say they definitely sell an adapter for those sizes at car parts store. it is plastic but still can handle gas. Hobby store sell metal hose connectors that small but from one size to another you have to look.
Mine is straight 1/4 hose. interesting...
The new ebay $11.00 Chinese carb came with around 3/16" fuel line and filter. I used the included line to fit the carb fuel inlet.
I rotated the fuel inlet tube to 3 O' clock like the OEM carb.
Need to remove the ball and spring to defeat the detent on the new choke lever. It works as is but gets stuck on choke at the handlebar throttle.
My linkages are all bent up from the previous owner. Trying to create a shape to get it to run properly. Trial and error with a tachometer.
Just wanted to report back on the ebay Chinese carb. It does work ok.
If you have the larger WI-185cc WR engine, these will work. Looks like the one I used a bit ago. Ebay link is below.
btp4571
I had purchased a carb off Amazon but was never able to get the choke lever to sit down far enough, also what did you do with the plastic bushing that came with the new carb? Also did you have any issues turning the fuel inlet?
I bought from Ebay. Don't know which carb you got????
Which engine do you have? 140 or 185cc?
btp4571
I got it for the 185 mine is on a 25th anniversary snapper, mine had the straight fuel inlet on the side.
That link I sent should work for yours. I forgot about the fuel inlet deal. Sold mine a couple years ago.
btp4571
Oh bummer, did the carb work pretty well?
Yes. Read this entire thread about how I made it work.
