Honda Tech
- Jun 3, 2015
- 0
- 176
Sounds to me like you did not replace the switch with the correct switch. Instead of grounding out the ignition in the off position, it was just cutting the voltage to the fuel cut solenoid, hence the 3-4 second lag to shut-off. Many switches may look alike, but the terminals serve different functions. Sounds like the buyer got himself a pretty good deal.
