BlazNT
- Apr 26, 2012
- 6,973
There is something that is being missed. So lets try a few things. You need to check your wiring with continuity test. I am ataching picture of what it looks like and what the reading should be if wires are good. Check every wire from beginning to end. Also check the spark plug. Yes they can be broken from factory. If the reading is not 000 then check for a fuse-able link in the line or broken wire or bad connection if connection plug is used. I hope this make since.
