wingless
- May 30, 2017
- Threads
- 6
- 81
My 25 year old 21” self propelled walk behind mower has finally reached the point of me being DONE with repairs, so I have retired that machine and selected this Toro as the replacement. Hopefully it will outlast me.
This Toro 21386 Personal Pace SMARTSTOW Super Recycler 21” mower is a very nice machine. One feature that helped steer my selection was the “military grade” cast aluminum deck, so that I enjoy the durability and impervious to rust of aluminum over steel.
After I got this mower, I discovered many features I liked.
The best feature is that everything is performed without tools.
The handle has two large (blue) ¼ turn flip toggles to release / engage the locks that secure the handle in the operating or stowed position.
The mower configuration is changed w/o tools. The side discharge chute slips on / off w/ a lever release. The rear bag is retained by hooks, under a large spring loaded door. The rear recycling plug is slid in / out and retained by a lever.
The machine may be stored vertically. I haven’t used that feature yet.
My after usage cleaning uses the easy flip it up feature to expose the bottom for garden hose cleaning. I have found that removal of the recycling plug and releasing the side discharge door permits full garden hose access that eliminates all grass residue. The machine has a female garden hose fitting and instructions for usage, but I have not used that garden hose connection feature.
The engine is running before completing the first pull. The machine is quiet, powerful and consumes much less fuel than my prior mower.
The mower provides a very nice cut. I have used both side discharge and recycling. I have not yet used the rear bagging feature.
The Personal Pace self propelled feature works very well. It is very intuitive. I have never operated it at maximum speed.
The blade cutting height is changed by moving a lever at each wheel. I cut at the middle setting.
The Briggs and Stratton model 104M020254F1 engine is touted as “No Oil Changes” required, just check and maintain the level. For Old School troglodytes, oil changes are possible by tipping the mower and dumping the old oil out the fill hole.
The engine pull cord handle is positioned near the safety bail / speed monitoring / operation handle.
The engine has no choke and no throttle. Just go and stop.
The machine has a rubber flap hanging below the rear axle that fell off / broken on my mower after just a few short uses. I think this is a safety feature to help prevent slipping under the rotating blade. The manufacturer requires bringing it into a shop for warranty service replacement, but I haven’t had an opportunity for that repair as I don’t deem it essential.
So far I like this machine and would not hesitate to recommend this machine to others.
