Will this pulley work? tore mine up
jross
Before going with Amazon.com check this one on Pat's Small Engines -http://www.psep.biz/store/cub_cadet_pulleys.htm-. It lists models after 2007, but check all the part numbers to match it to yours. You can also e-mail or call them and they'll do all they can to help you. I got Oregon spindles from them with blades for our 1600 at $43 each. Amazon wanted $70. Also remember many MDT parts will fit Cub Cadet.
Also you might check mymowerparts.com ... Do you have a part# for this pulley? The pulley on the Amazon link appears to have the correct center shape for the shaft..
Sammy the Red
Did your Cub Cadet dealer have one ?
KennyV
Those thin spline centers without hubs usually also damage the shaft... if it has any damage at the spot it attaches it will fail again soon, look very close and measure for ware...
If that pulley has the same OD, ID and spline count... it should be fine... :smile:KennyV
platinumaa
Perfect.. i appreciate all the responses.. thanks fellas
