I have a 2007 22" Toro Personal Pace mower with 6.5 hp Tecumseh motor that uses a blade like this:
My Father has a 2009 22" Toro Personal Pace mower (primer-less, with blade clutch, & bag/mulch select) with 6.5 hp Briggs motor that uses a blade like this:
I am at work right now and will post the model numbers for both mowers later (I do not have both mowers but I did write his mower's model and serial down for reference of parts.)
I have not attempted to "swap blades" for $hits & giggles yet, but I always thought that my Father's mower cut better and finer than my mower.
Has anyone swapped blades without changing the blade adapter? I do not recall if the newer mower's blade has a concave shape to it like my older blade.
