Old fiddler
I mulch - the nitrogen is good for lawn growth. If the grass is very long, I cut 1/3 of grass blade length, then go back at 90 degrees and cut another 1/3 blade length. If the length of the grass is still too long, I repeat the procedure in a few days.
Then I try to maintain the length of grass I want, without letting it get too long again
Fertilize 3-4 times a season with appropriate fertilizer- seems to give good results.
Keep your underside of your deck pretty clean, it will not clump as much if at all
