LarryJohnson
- May 30, 2017
- 34
- 131
I've been trying, unsuccessfully, to diagnose the no-start issue with my mower; Murray 425009x8A with B&S 31R907-0007-G1 engine. It died while I was mowing.
The flywheel spins and I can get it to run at 1/4 power for a second or two. I've been assuming that a bad switch would be like disconnecting the battery, preventing the flywheel from turning. Is this a correct assumption.
Thus far, replaced the carb, coil, plug and gas.
