ttimtucker
Generic question for the gurus on this forum: I know there are some mowers where the only adjustment related to valve lash is to grind the stem to shorten the valve. My question is this: what is happening in the engine that would make the valve (or something else) "too long", such that shortening it is appropriate? My expectation is that engine operation will slowly wear things down and increase clearance between cams and push rods and valve stems. What mechanism is causing the clearance to decrease?
