R Rivets Lawn Royalty Sep 29, 2013 #12 Just look at section 3 of this manual. It will tell you everything you need to know. http://dl.dropboxusercontent.com/u/12502267/B&S Service Manuals/01_270962SingleCylinderLHead.pdf
briggs Well-Known Member Oct 2, 2013 #13 Rivets said: I assumed that by pulsing he meant surging. Haven't seen lawn mowers with pulsa-jet carbs. These carbs were used on horizontal crankshaft engines. Click to expand... yes u are right opps i stand corrected they are a vacu jet carb but i did say replace the diaphram gasket .....
