banjomaniac
- Mar 25, 2014
- 8
- 22
The deck spring came off after I hit something and I see the bracket in the rear but not positive where it connects to pull deck back for belt tension. There us a bracket the deck connect or hangs from that is s big square with a big round cut out and that has a shaft towards the rearrear that it might connect to. If anyone has this mower that could take a quick pic just look under the rear or back between back tires that spring is easy to see. Also it is TIGHT and hard to stretch that far. Maybe hook a thin rope around one end to pull it back. Any ideas? Thanks banjomaniac
