jekjr
- Jan 3, 2013
- 271
- 1,969
I see various posts on here concerning zero turns and which ones to purchase.
In our area there are several different dealers. You can get about any commercial brand you can name and have been able to for several years.
There are a lot of people here who cut commercially and have been for years.
We had been looking at starting up a commercial lawn service for for several years as well but every time we started to do so we would have something else come along that we would do instead. Therefore we have been looking at mowers and other equipment for a while comparing to get a good idea as to what was out there and what to expect...
I finally fulfilled all obligations that were keeping me from starting up last July and set about in earnest starting up. Long ago I had made up my mind that I was either going to run Skag or Kubota mowers. I then started to notice the operators that were running those two.
I see many people that have bought the other brands and traded brands. I have never seen anybody running either of the two that traded for one of those others. Normally if they buy new equment they buy Kubota. I have never heard of a commercial operator that replaced mowers that had been running Kubotas that went back to any of the others. I have seen many of the others that bought new and got Kubotas.
Every operator that I have ever talked to that ran Kubota has said that they would not go back to anything else.
We bought a Kubota ZG 222 last Aug to start up and it now has 150 hours on it. We had to replace a deck belt that we damaged probably by a limb while mulching leaves last winter and we had a seal on a deck drive gearbox that had a vent plugged and blew a front seal a couple of weeks ago. Again probably from mulching leaves. It has been hammered in those hours.
We just bought a ZD 326 and it has less than 10 hours on it. If it gives us the service that I see other operators that have been running them for a long time we will be pleased.
Because we cut so many yards that are rough and have Bahia grass in them these mowers take a pounding every day. The Kubotas I have been observing some of which have been running for years are still hanging in there. Most of the others only last a while and they are ready for the junkyard.
I have heard the argument numerous times that to spend the money a Kubota commercial costs is a waste of money with all of the cheaper commercials out there and that all you are doing is paying for a name. After observing these others for a while and now buying the Kubotas I think that the people that say that really do not know what they are talking about.
If you are going to buy a mower to cut your yard then cheaper might be figured in. If you are going to cut 20 or more yards a Kubota is something you need to strongly consider. I know we did.
