which spark plug for 4.5 HP engine
EngineMan
Actually the Y designates the plug as one of the new Pro-V line. That line replaced the older Commercial Series plugs. Same heat range as the regular plug...
Are you sure because I got it off the NGK spark plug chart, and that the two main plugs for the BRIGGS & STRATTON ENGINES are BR2-LM and the BCPR5ES
Will have to ask NGK sales rep when I see him...!
pugaltitude
NGK for Honda and Champion or Torch for Briggs.:laughing:
Retiredcarguy
NGK is the best way to go for many engine applications, small and large.
AnthemBassMan
Don't know if this link will work, but this is a page from NGK. On there, all of the plugs ending with a Y are the newer Pro-V. Basically looks like they took the regular V-Power plugs, and designed them for small engines. Maybe I'm misreading it, but that's what it looks like to me...
L8R,
Matt
EngineMan
That is just a group of plugs under the name Pro-V if you look you will see that there is one in the list that ends with a E, on the NGK Horticultural, Agricultural and Industrial Applications chart (2012) it shows under the heading Firing End Construction, etc That Y = V-Grooved centre electrode with extra projection.
so I rest my case.
AnthemBassMan
so I rest my case.
I must apologize for that. I confused your post from Davisrf where he was wondering if the Y may mean a hotter plug.
L8R,
Matt
EngineMan
Numbers are used for the heat rating...!
