The engine on my 2006 troy bilt 42" sezied. any guess which one it was....yes Kohler courage 19 HP SV590. I opened the engine as I was hell bent on understanding what had gone wron. The crank shaft is binding - piston, con rod, valves, cams, motor, pumps, gears are in excellent condition. The damn rubber tube from the pump to the lower crankcase failed/damaged and pulled out casue the bearing to fail.
Rather than spend $600 on repairs, have decided to buy a new Lawn Mower.
Need some advice on which riding mower do people recommend. I dont have courage to go in for another Kohler given the reviews on this engine and a gaurantee of problems!
my yard is .5 acre.
I do have a steep hill on one side (hours has a walkout).
need it only for mowing grass
Yes need a nice level cut
Would prefer 42" as I bought a $300 bagger for junk troy-bilt 6 weeks ago
Need it last a lot more than 6 years for sure
budget is $1600 (definitely not $1800)
I have done my research but given my limited understanding look to hear your experiences.
my yard is .5 acre.
