Hi I am looking for a husqvarna push lawn mower, to mow an acre slight slope. Which would be better, the 5521, or the 7021? Also, which one would have a better life span? Thanks
The 7021 is the better of the two, engine spec's are a lot better. The Honda engine on the 7021 is a far better engine and will last probably longer than the Briggs.
[TABLE="class: compare-table compare-table-extended"]
[TR="class: techdata-row"]
[TH]Engine manufacturer [/TH]
[TD] Honda [/TD]
[TD] Briggs & Stratton [/TD]
[/TR]
[TH] Engine type [/TH]
[TD] GCV160 [/TD]
[TD] 550 Series [/TD]
[/TR]
[TH] Cylinder displacement [/TH]
[TD] 160 cc [/TD]
[TD] 140 cc [/TD]
[/TR]
[TH] Net power at preset rpm [/TH]
[TD] 2.9 kW @ 3000 rpm [/TD]
[TD] 2.2 kW @ 3000 rpm [/TD]
[/TR]
[TH] Power [/TH]
[TD] 4 hp [/TD]
[TD] 2.9 hp [/TD]
[/TR]
[TH] Fuel Tank Volume [/TH]
[TD] 0.95 qt [/TD]
[TD] 0.95 qt [/TD]
[/TR]
[TH] Engine name [/TH]
[TD]-[/TD]
[/TR]
[/TABLE]
