sofasurfer
- Jun 1, 2020
- 64
2010 Cub Cadet LTX1050VT. Hydro static trans is Hydro-Gear 618-0319.
Tractor barely moves and will not move at all on the slightest incline. Changed belt and had no effect. Does this PROVE that the trans is bad? Could I have a linkage problem?
When I push the pedal either forward or backward there is a linkage that moves a lever on the trans. This lever only moves in one direction no matter which way you move the pedal. How far should that lever move? It only move a tiny bit.
That is the only thing that looks suspicious to me.
If it is decided that I do need a new trans (used) is the 618-0319 the only one I can use? I saw a reference on a parts website that indicated the the 311-0510 is the same trans.Is this true? Are there other trans that will work, INCLUDING fitting on the tractor? Does the serial number have anything to do with its fit-ability? Can I only find a trans from another Cub Cadet or do other mowers use them?
This is a really strong running tractor (I think) and in pretty good condition. If I can find a good CHEAP (if not free)trans I'll have a great mower.
Thank for any help. I'm in Davison, Michigan if anyone has one.
