I finally decided to replace my Toro Recycler with the broken front drive which has also had other issues. Tired of putting money into a troublesome mower.
I have looked at several brands and have decided on a Honda. The models I am deciding between are the HRX216VKA and the HRX217VKA. The question I have deals with the transmissions. The 216 has a "variable speed fixed gear belt clutch" while the 217 has a "cone clutch variable speed transmission". Can anyone please tell me if there is a significant difference between the two types of transmisions?
I would prefer not to spend the extra $'s on the 217 but if the transmission is significantly better I will. My lot is between 1/3 and 1/2 an acre and about a half of that is a slight hill.
Thanks
Thanks
