Where is this part from?
Finnishboy81
where is this part (string) from?
the break pedal is loose and the murray doesnt move properly. Everything else works fine. C0C3A713-3C6A-462A-9D41-96ECB1BCA40D.jpeg
Thanks for the rapid answer! :)
Take your model number and look up a parts diagram for your unit. You are correct it is a brake return spring and the diagram will show where it goes.
