where does this part go?
troybilt pony
trying to put together the pieces and forgot what went where.
reynoldston
Looks like the crankcase breather tube, should go to the air cleaner
That plastic piece and the associated linkages go on the opposite side of the carb from where they are now. You may have to re remove the carb and tank to get it where it goes. There should be a small threaded hole close to the carb mounting screw. it has a screw with a 5/16 head with about a 1 inch shoulder.
troybilt pony
i looked at an old photo i posted and see where its suppoed to go.. at the bottom of the fuel tank there is a spring. do you happen to know where its supposed to go?PIC_0319.jpg
That is the governor spring, It goes between where it is now and the governor arm.
troybilt pony
almost to the finish line guys.. does the hook go onto the top or bottom hole of the white piece?PIC_0323.jpgPIC_0324.jpg
