davidblaine
- Jul 1, 2020
- 7
I took the carb off my Stihl FS44 string trimmer and there is a hose coming off the gas tank, but where it runs to, I can't tell. When I took the screws out and removed the housing it was already lose, so I didn't remove it and am not sure where it goes. There are two other lines from the tank, a very short one to the primer bulb, and the main, filtered line to the carb. This must be either a vent or a return? I am attaching a diagram. The hose is number 12 and the connector is number 21. Can anyone advise where to route that? I don't see any obvious place on the carb.
