Where does the Blue wire ( power to clutch) connect - Husquavarna lth130
rhodyzoo
Mower stopped and has no power. I checked and there is power from battery to ignition witch. Then I found the blue wire from the blade on/off switch dangling. I cant locate where it is supposed to connect. This is teh power to the clutch/safety switch
Sounds like you got a LTH130 instead of a LT130
The blue wire goes on terminal "B" next the red wire which is terminal "E".
