Where does the Blue wire ( power to clutch) connect - Husquavarna lth130
rhodyzoo
  • / Where does the Blue wire ( power to clutch) connect - Husquavarna lth130
Mower stopped and has no power. I checked and there is power from battery to ignition witch. Then I found the blue wire from the blade on/off switch dangling. I cant locate where it is supposed to connect. This is teh power to the clutch/safety switch
Sounds like you got a LTH130 instead of a LT130
The blue wire goes on terminal "B" next the red wire which is terminal "E".
rhodyzoo
i mean the other end. the switch is fine but its dangling down near the mower deck
rhodyzoo
attached to plug and the other end just dangles
