Where did I go wrong?
we had a clean room for the racing engines. As in special filtration etc.. I build engines on the work bench but the area is spotless when I am working there. My hands probably get washed a dozen times an afternoon while assembling. I feel everything for grit. It goes thru a safety Kleen parts washer, then compressed air, then hot soapy water, then hot clean water, then compress air again. And into plastic baggies if it is not being immediately used. I keep very clean towels to lay over top of it when I take a break.
If you are that clean with your engines, maybe something else is going on. I think it was Project farm or someone who recently did a program on testing what grit does to an engine. He bought four or five new engines, and added a little grit, swarf etc., to each engine. Then ran them until they dropped. The worst killer was the grit used in valve lapping compound.
WOW, looks like the OP ghosted his own post. Nice fat X in reply #1 now. Sucker didn't even give us a thank you.
Okay, wonder what in inside of his house looks like?? :ROFLMAO::ROFLMAO::D:unsure::poop::poop:
