Here’s something to check when you turn ignition to start and only get a click. Reach under each control arm and push up the plunger on the safety switch and then try to start the engine. My Raptor XDX’s safety switch plunger on the left control arm wasn’t being pushed in far enough to activate the switch. Pushing the plunger all the way in with my finger activated the switch and the engine started.
