dakotamanb
- Jun 19, 2012
- 4
While mowing my front wheel collapsed.Its like the wheel is dangling on the mower where you ajust the height.It is aMurray selfpropelled#22617x92b? Thanks Tony
Did the wheel break or the nut holding it on come loose? This model looks to be self propelled. You can find the parts for sell along with a diagram here at PARTS TREE .com
the spring clip on the wheel came off any idea on how to get it back on. thanks tony
If you mean the height adjuster it should bolt onto to the deck as seen in the diagram.
I think the part # is 011x16ma
:confused2:
You will probably also need the nut that the bolt threads into on the other side of deck which is 015X68MA. I believe this is the size of the nut 015x68 as well as the bolt size is 011x16. I am not sure of this maybe someone else can chime in on this. :confused2:
