turbofiat124
15.5 I/C OHV engine, 2005 model. Well that was when the mower was built. Assuming it's the original engine.
I acquired this Murray riding mower.
Every now and then when I start the engine, the starter motor will spin but the bendix won't engage in the flywheel. The reason I believe this is I can hear the starter motor spinning really fast.
I thought perhaps the battery could be weak but usually the engine drags. What I suspect maybe going on is the bendix is not be "slung" upwards into the flywheel at times. My guess would be that the shaft the bendix rides on maybe gummed up. Then again I thought maybe the battery is weak and it's just not spinning fast enough to engage the bendix.
I pulled the engine cover and the bendix looks fine, it's not stripped. I could move the bendix easily with my fingers but I sprayed some Penephite lubricant onto the shaft anyway. Since then I have not had this happen. But have not used the mower that much. I just did some maintenance on the engine and parked it in my storage building around back. it's too soon to tell.
I'm curious if there is anything else that might cause this if it's not the above two conditions.
Also I have a 15 HP Briggs engine from my old Snapper that threw a rod through the block I am hanging onto for some odd reason (parts?). I believe it was made around 2000. Any chance the starter from this engine will fit the 2005 15.5 I/C engine?
