What tools are essential for lawn care?
Walter Reeves is a well known gardener in the Atlanta area, and he used to have a newspaper column back when newspaper columns were a thing. Someone once asked him about his lawncare program. His main thing... mowing. He recommended mowing frequently. The rule of thumb is to mow to the best height for your grass, and never mow more than 1/3 of the length. So, say, you want to mow to 2", you should mow when the grass gets to 3". This does more for your lawn than fertilizing, but only mowing once a month. Mowing often gives the grass the best chance of out competing the weeds.
You didn't mention the size of your yard. For a mower, I'd get whatever I would actually use to do the job. So, say, you have a large yard that takes 3 hrs to mow with a push mower, and as a result, you don't mow as often as you should... get a bigger mower, or a riding mower, and mow more often. A push mower IS good exercise, but only if you use it. IMO, it's a good idea to get a mower that is suited for your yard. One time I replaced a riding mower with a self-propelled push mower because the front yard was so sloped that the push mower didn't take any longer, and took up less storage space. When I moved to my current property, I got a 54" ZTR which still takes 1.5 hrs to mow my yard. A push mower would take 4 hrs or so. Whenever I move to a new house, I usually replace my mower with one that is better suited for that yard.
Someone recommended a Stihl or Craftsman week wacker. I'd recommend Echo over both of those, and especially Craftsman. Stihl is as good as Echo, but tends to be harder to start, and repair parts are more expensive. I'd recommend Echo's PAS system, which takes attachments, and the attachments I'd recommend are: string trimmer, edger, and blower.
Hi guys , Hope you are doing well. I am looking tools for my lawn. Besides a lawnmower, what tools are essential for good lawn care?
Great question! When I first started caring for my lawn, I quickly realized that having the right tools makes a big difference. In addition to a lawnmower, here are some tools I’ve found essential:
  1. String Trimmer (Weed Whacker): Perfect for tidying up edges along pathways, fences, and hard-to-reach spots.
  2. Garden Rake: A sturdy rake helps clear debris and level soil when you're reseeding.
  3. Lawn Aerator: Vital for breaking up compacted soil, improving water and nutrient flow to grassroots.
  4. Fertilizer Spreader: Whether you're applying seed or fertilizer, this tool ensures even distribution.
  5. Hose and Sprinkler: For consistent watering, especially during dry spells.
  6. Pruners/Shears: Great for trimming bushes or small trees near the lawn.
  7. Edger: Helps create clean, defined borders for a polished look.
If you’re new to lawn care or simply want to save time and effort, I’d highly recommend reaching out to professionals like Seacrest Services Inc. They provide top-notch landscaping services and can tailor their approach to your lawn's unique needs. Check out their website to learn more!
Wow, great tips! You’ve covered all the essentials for lawn care. I completely agree—having the right tools really makes a huge difference. I’ve found that a garden rake is super helpful, especially when reseeding, as you mentioned. Also, the lawn aerator has been a game-changer for improving soil health in my yard.
One thing I’d add is that sometimes a leaf blower can be useful for clearing up leaves or grass clippings after mowing, especially in fall. And if you’re dealing with a lot of weeds, a weed puller can save you a lot of time too!
I do most of my cutting at 85 degrees or lower here in South Texas, so than means early morning after the dew has dried or late evening in most cases. Headlights on a rider come in handy.
Hi Arslant001,
1-rider for big areas
1-push mower for closer cutting and trimming.
1- weed eater for finish trimming.
1-blower for any sidewalk areas.
Other than that, a rake and broom and needed
I consider round-up a tool . The last concentrate i bought was 54 bucks for 2 gal . Mix 6 fluid oz. to a gallon of water and make yourself a sponge swab to apply on unwanted growth . I have 2 swabs to pinch some plants between and a 2 gal. jug lasts about 5 years . I do spray some if the growth conditions require it .
That's a smart way to use it! Making it last 5 years is definitely getting your money’s worth
Surviving the "jungle" called yard work: Water in the morning, a Mountain Dew and a snack cake around 10AM then a good lunch. If it lingers into the heat of the day, constantly drink "cool water" not cold water. Saltine cracker for a snack also helps.
Beer or a mixer is only after the work is done and the equipment is cleaned and put away.
As for equipment.... One of the best tools I have purchased to date is a DR push type string trimmer. It makes most handheld weed eaters look like a toy. I have several buildings and some trees that I have to trim around, so it works efficiently and quickly.
Other members have provided some good input so I will not elaborate further, except do try to do everything at one time or buy all of you equipment at once. Everyone has different needs and gradually learns what works best for them.
