What to pay for Kubota
strikeswhilehot
Looking to purchase a used Kubota riding mower and new to this forum. Thanks for any feedback regarding price and value.
Found this mower locally. Your thoughts?
Described as
Kubota HST 1400 Lawn Tractor–1996:
In very good condition
Kubota LT 14 hp
40" cut in great condition
1996 model last year made!
Has Twin bagger system!
New tranny belt
$1250
I would say it is over priced. At 25+ years old going price for that model is $400-$600 Bagger would only add about $100. They were a great unit in its day, but I would only pay a max of $600, knowing that it may come back to bite me.
bkeller500
In comparison, what else have you found that is comparable for $ 1250?
strikeswhilehot
thanks for the comparison Rivets. Around here this would compare to a newer TroyBuilt or a slightly less new John Deer. Thoughts on those?
Thanks
grassmann
Outrageously high
Shady oak
This may indeed be too high, but as a rule I will always ratner have a good used older model, than the newer stuff they put out now. I have a G2000 with a 60” deck, and a F2560 with a 72” deck. Both about 25 yrs old. Just comparing the decks alone to newer decks is impressive.
oneoldsap
Look it over . If it has been properly cared for , and used on a residence , with the bagging system . I would say it is worth haggling with the seller . You didn't mention if it has an hour meter or not . If it does , I'd want it to be 500 Hrs. or less . They are easily a 1,000 to 1500 Hr. machine , with proper maintainence , and use !
Described as
Kubota LT 14 hp
New tranny belt
$1250
oh ive got sources i can hook you up for 1000
lugbolt
Many parts are no longer available for the T1400. I would pass on it. If you just have to have it, $100 tops knowing you'll have a hard time getting repair parts for it.
