What model troy-bilt do I have?
Sancho
Decals originally showing model is missing. Serial number removed.
Front casting is TH-1003 HF
Rear casting is TH-1002 HF
Neighbor says it is a HORSE.
I need to order seals for axle and belts.
Engine has previously been replaced with a Briggs-Stratton 5hp.
Any ideas so I can order the correct parts? Let me know if further action is needed.
If it is the original horse from several years ago. the serial number should be stamped into the transmission on a little tab that sticks out on the right side next to the top cover. those casing numbers do sound like what I have seen on the horse models.
I'm still putzing around with my tiller. Cleaned the axle seal and found stamped on it : 132-100-625 also found manufacture ( maybe incorrect) IRUSILL?
If you can, let me know where I can order a pair of seals. Also the seals on the rear tines is also pretty greasy, do you know a part # that will fit my machine?
Next problem is how to remove engine from unit, I think the pulleys are rust welded to the engine shaft. Any ideas would certainly be helpful.
Thanks,
Harry
I have a serial number 225766. Will this help me to identify a Model?
