Scraperman
I have a ride-on Scag that is quite old and I think I may have a very serious problem with the engine, a 20hp Kohler (details below).
Basically, although the engine will fire and run for a few seconds it then slows right down and stops. I then discover that there is engine oil in the carburettor and air cleaner, also dripping out of the exhaust, and when I first noticed all of this it had also leaked out of the engine oil filter which was slightly loose, I wonder if this may have been because the rubber sealing ring of the filter may have been fractured because of back pressure.
My first reaction was that some or all inlet and exhaust valves must be permanently closed or open for some reason. Or has one or more of the piston rings broken and thus allowing oil to get on top of one of the pistons which in turn is throwing it out through the inlet and exhaust valves ? The only other thing that I can think of is that the engine breather is totally blocked.
I would appreciate it very much if anyone on this Forum could suggest what the problem could actually be or shed more light on the problem in any way. I have very limited knowledge of this type of engine. Thank you for reading this.
