What fluid to use
neighborbill
I have a Scags Turf Tiger and it says I should use 10W-30 motor oil for the hydraullic fluid pumps. I've never changed that fluid before and using motor oil for hydraulic pumps makes me a little leary.
Comments from anyone who has made this change?
Thanks
Hydro gear has used 20W50 motor oil for years in their hydros. So if your manual says to use 10W30 then use it.
Born2Mow
Two choices:
  1. Go back to engineering school and then work 20 years in the hydraulic design industry.
  2. Follow the instructions.
