.... I have found a great liquid product that is has kelp and some other goodies in it that the dogs seem to find less attractive. I am looking into building a small sprayer that I can tow behind my Wheel Horse. Has anyone ever done this?
I have made sprayers to apply stuff like you are describing...
You will need a high volume pump...
diverting a lot of your pumped liquid back into your slurry tank, that will keep it mixed up... you will have some problems with kelp & moss, run through a sprayer...... but I use to spray that also... I would let it dry then gather it up, it would break up almost into a powder... mix it in my tank, set bypass line to keep tank mixing...
Made my own spray nozzles, using steel pipe caps OR plugs... take a 4 inch angle grinder with a cutoff blade in it.. plunge cut a slot into the cap, the deeper you cut the wider the slot... depending on how many GPM your pump will deliver, bigger pump, deeper slot... I was spraying some thick stuff so I had to make my own spray heads... the finer ones would plug up...
But it's fun to experiment with various spray patterns and you can make sprayheads cheep & easy... :smile:KennyV
