What do the 'dashes' indicate ini Kohler parts manuals?
MattG.inAZ
  • / What do the 'dashes' indicate ini Kohler parts manuals?
I happen to need a part that is encircled by dashes but cannot find the part numbers.
Scrubcadet10
Moderator
Staff member
thats the outline of the mower, to show the parts in their relation to position or placement on the mower.
Which part do you need?
Scrubcadet10
Moderator
Staff member
MattG.inAZ
MattG.inAZ
Just amazing. I'm not sure I would have ever figured it out. I looked for an explanation in the text, but no go.
thanks for the info. Onward and upward.
Thought I had it. But no. I need the connector that is located in the front right tire in the pic. how do i find it?
Are you referring to this one?
If so normally it is only available as part of wiring harness. But it is available otherwise when you know that it is an Aptiv connector.
02984883 Male connector housing. Matching Female connector housing is 02973781.
Now what gauge terminals do you need 16ga or 18ga? To install these you need the open barrel crimper. Here my open barrel had to be modified to install the male terminals.
MattG.inAZ
View attachment 64514View attachment 64515
Excellent. I found a Kohler catalog which had this connector. We'll see. In meantime I'm going to order the male connector. The harness I got has a female connector and the original harness has a male. Go figure. Thanks for these part nums. I've got the tools for making connectors as I was restoring 1982 Honda 750s. Got the spades and all that stuff. Now I know it is Aptiv!
