What are correct idle & max rpm for Briggs 10.5?
Maxrevs
Hi guys, can anyone tell me what the correct idle and maximum rpm should be for a 10.5 I/C engine?
Year approx 1998 and Engine ID is: Model 28B707, Type 0146-01, Code 970318ZB and the carb is a Walbro LMT 5-4993.
Thanks
A lot will depend on the type of equipment the engine is used on. Ball park figures are 1400-1800 for idle and 3200-3600 for high speed. Again these are ball park, some units go as low as 1200 and as high as 3800. Hope this helps.
Not familiar with that piece of equipment, but being a type of lawn tractor, I would set idle at 1400 and governed top speed at 3200. This is based on past experience, not coming from a manufacturer. Some one may prove me wrong.
