weedeater
One thing I would not recommend is the 4 cycle version that uses an oil dipper system. Many may just make it through the first before they burn themselves from lack of proper oiling. Troybilt 4 cycles are one the worst I have seen here. The main problem is that you operate them level and not inverted due to the oil dipper system.
Now Stihl makes some excellent 4 mix trimmers. They true 4 cycle trimmers that use 2 cycle fuel mix. Shindaiwa also make very good 4 cycle trimmer that have oil pumping system via reed valves where they a separate oil tank and uses straight fuel.
As owners trimmers Homelite did make good trimmers but I don't know about the latest models. I have however used the older model quite heavy on the 14 acre farm.
logert gogert
uuuum, i actually posted the wrong link...oops lol
mine is actually a 2cycle
logert gogert
so just forget about the link.....
but every thing i said about MY trimmer is true
the only bad thing about it is it seems to lea gas, not from the tank, but i think it coming from the carb, when ever i go trim, i always notice the air intake has some gas in it...any1 know why???
Echo trimmers only have a two year commercial warranty, but 90% of the commercial guys around here love them.
bogdaN
I vote for Homelite ST-155 or newer Not the China made.Those old curve shaft runs forever and last vibration comparing to Featherlite.
7394
Actually the Shindaiwa is probably the same Echo just in drag. Both companies have merged.
I'm aware of the merger.
The diff between the Shin & Echo are that the Shin has a soild drive shaft. Echo does not.
And has a full protection guard under the fuel tank as opposed to the 1/2 one on Echo. I could go on. But I like my Shindaiwa.
