I have an IDC weed trimmer. Seems to be an odd-ball brand, but at least it was made in the U.S.A. I bought it at a Big Lot store for $44 about 30 years ago but now it's become very hard to start and keep running, so I may replace it because it doesn't owe me anything. Worked great when it started and ran. Once the piston got glued inside the bore after I ran some very old gas in it and I had to soak it in varnish remover and pound it out. Also the primer bulb hardened and cracked and I had to search for a replacement on-line because no local small engine places had one.
