Ric
 - May 7, 2010
 - 139
 - 5,765
Yeah my back hurts when I use my regular trimmer especially after more than 45 mins of use. Any videos I've looked at online of the handlebar trimmers make it look easier to stand up straight. The only thing that would concern me is getting it under trees etc. the regular trimmer is more maneuverable I would think. Also, trimmers are heavy!! Any light trimmer I've used has lacked power.
The bike-handle trimmer is used or supposed to be used for cutting on inclines or when things get dense and standard trimming line doesn't do the job. It should be used with steel grass, brush and saw blade attachments. If your back hurts when using a trimmer there are a number of different strap designs available that will hook to the trimmer just in front of the throttle and go over the shoulder to relieve the pressure on the back. I'm afraid handlebars for regular trimming would be worse to use than just the trimmer itself on the back. Thing is if you use the handlebar you still have too use the strap, it's just double trouble.
