Cheetah 72" model scz72v-921fx has weak spark when first trying to start. After cranking for 10-15 times it will start and run fine. Tried hitting it with starting fluid just to confirm that it is not a fuel problem and still no start. This model has and engine module on it that I suspect may be the problem but it is expensive so I need some help before I drop $100 that is not needed. Thanks
