Weak spark
gregmartin
Will a BRIGGS AND STRATTON 6.75 HP. Engine start with a weak spark.
I can't even get it to pop,when I look at the plug its wet so it getting gas.
I have to spin it pretty fast with drill to get a weak spark and no spark when I pull by hand.
Thanks.
So for all practical purposed you do not have spark. Either partially grounded kill wire, faulty spark plug, or faulty ignition module.
Tinkerer200
I would take the Ignition Coil off and brighten the mounting surfaces on both the coil and mounting surfaces. Be sure the air gap is correct. Disconnect the Kill Wire and see what happens.
Walt Conner
activelife92
As stated, look at the ignition system. It could be the ground/kill wire, or even a failing coil. Sorry for the dumb question but is the plug new?
gregmartin
So far I disconnected the kill wire with same results.
The plug is not new but looks pretty good.
I did regap the coil to 10 thousands, I wasn't sure exactly what it should be. Every thing did look clean but I'll clean it better tomorrow
I thought a coil is either GOOD or BAD no in between, I assume they can become weak
Thank you for the ideas.
Michael72
Coils can go weak...but I would change plug first tho and clean contact points on coil and flywheel as said above....your gap should be fine...I have often increased gap over spec for best results...something often overlooked when a PTO wont engage!!
gregmartin
Problem solved, runs GREAT. I'm not quite sure if it was the plug, regaping the coil or sanding the contacts but I do know that I turned
my FREE CURB ALERT Lawn Mower into $75.00
Thanks again guys for your help.
Michael72
Happy days!!...win win!
