fatdaddy09
- Jul 27, 2014
- 1
- 1
I have an x mark 72" 27 hp liquid cooled mower,i was mowing the yard and it shut off ,notice water was low so i put 2 qt's in it still didn't look full so i started it up drove over to water hose to fill up radiator.
Then water started to come out air cleaner i trained oil took out plugs and turned engine over and seems to be ok no lock or knocking sound.What may have caused this i am going to flush engine with some diesel
and change oil & filter and plugs. Do you think it will be ok
thank you fatdaddy
thank you fatdaddy
