Water in Gas, Help Needed!!!
Pat M
You see water in the containers, it does not mix with gas, oil does mix with gas. Now do all the stuff they mentioned above, but take off your fuel filter and leave your gas cap off overnight let evaporation help you. FYI, ethanol gas, moreso than non E, will attract water without leaving a clue as to how.
Thank you. I cleaned up the tank a few times because of water & debris in the gas.
Today I hooked up the fuel line directly between the fuel pump & the gas can. It started, I believe I know what the problem is.
'https://share.icloud.com/photos/0c8zjbCk2mhuWwSdkD4-dOF_g
