walkerMDG turns over but no spark
walkerone
I have a 2001 MDG with the Kubota 24.5hp gas engine. My battery died and after replacing it now I have no spark. The engine turns over no problem. Everything else works too (cooling fan, warning light and buzzer) just no spark. I checked the plugs and replaced them. I put a new ignition coil in. It started twice and now won't start again, still no spark. I have power to the coil. I checked relays and cleaned them, one was very dirty. Also for several years I have had a bad spot in the starter that caused the engine to not turn over sometimes, i don't know if this might be related. I would appreciate any help. Thank you
