Walker PTO Shaft U-Joint
jwcloutier
Has anyone had luck finding an aftermarket u-joint replacement for the T23 series? Dealer says the entire shaft must be purchased. That seems silly. This is the u-joint that goes in the 5285-5 shaft assembly. Hoping Napa or someone like that has one.
Just a matter of knowing the inside ear distance and cap size as it appears they used clipped cups. Then I can try to find the correct u-joint.
