Price Check Walker parts assistance
fwfd
Hello everyone, I'm new here. Thought maybe someone here could offer some assistance. I have a small engine shop I run when not at the Fire station. I bought most of the inventory of a large mower repair shop when the owner retired. The Walker inventory has been a headache finding some part proper names and pricing.
Here is a list of the part number, I've identified most of them but the pricing is mostly in question. I'm selling the Walker inventory on Ebay and it helps to know the price so as to offer good deals. If you know the price of the part please let me know or maybe a good place to find the prices.
Thanks in advance.
Part numbers:
3530-3
4026-2 Pre- Cleaner
4108-1 Cable
4215-4 Steering Retro-fit Kit
4219 Spring
4236 Pulley
4349-4 Flanged Bearing 3/4"
4950-2 PTO Switch
5025-2 Seal, Input Shaft
5025-3 Seal, Control Shaft
5025-8 Bearing, Input Shaft
5027 Lockout Mount
5028 Lockout Lever
5054
5082 Fuel Tank Cap (includes 5082-2 Fuel cap seal)
5083 Fuel Cap
5083-2 Tank Tube Elbow
5088
5088-5 Air Cleaner draw latch
5088-12 Air Cleaner Assy.
5091-10 Flow Indicator Valve
5108-1 Control Lever, Throttle & Choke
5108-4 Cable
5108-8 Control Bracket
5140-2 FSC Friction Body
5141 FSC Friction Washer (1 1/2 x 3/8 x 1/16)
5142-2 FSC Actuator Cam
5145 Gas Spring Assy.
5147 Spring Clip
5155 Gas Spring Assy / Catcher Door
5155-3
5157 Catcher Door Gas Spring Kit
5162 Wheel, Roller (5" Rubber)
5172 Nylon, bearing (.255ID x .379 OD x .250)
5192 Spring Plunger
5208
5212 Transmission Control Arm RH
5217 Steering Lever Pivot Pin
5219 FSC Extension Spring (3/4 x 6 3/4)
5221 Spring, Extension
5222 Spring
5223 Spring, Extension (1/4 x 5 1/2)
5224 Spring, Extension 1 x 4
5230-2 Belt
5235-2
5240-2 Pulley,
5242 Pulley,
5244
5245 Idler Pulley (3")
5263
5265 Bearing (3/4) Jackshaft & PTO Idler
5267-1 Retainer Collar (1")
5348
5406-2
5450 D-Clip
5451-3 Steering Lever Assy LH / Adjustable
5463 Steering Lever Actuator
5500
5519 Actuator motor (12/24 volt)
5530-3 Chute
5566 Strap
5588 Rubber Bumper
5594 Vane Assy Grass Pak Switch
5595-2 intake cover / GHS
5683 Caster, Bushings
5683-1 Pivot Bearing
5706-4 Seal, Protection Plate
5732-1
5735
5743
5743-1 Spring cover
5743-2 Counterweight Spring
5743-3 Eyebolt
5743-4 Eyebolt (3/8 - 16 x2 3/4)
5747 Tilt up latch kit
5775-2 Hitch Pin
5786-1 Deck Lift Rod
5802-2 Label
5803 Label
5815 Label
5830 Grease Fitting
5839 Hook bolt, Battery mouunt
5840
5843-1 Clutch Spacer Washer
5843-2 Clutch Spacer Washer
5844 Battery Hold-down bar
5845 Bumper
5885 Armrest Option Kit
5897 Clamps
5929 Solenoid
5932 Battery terminal insul (black)
5933 Battery terminal insul (Red)
5940-4 16-14 Ga. Spring loaded term. Female
5942-5 Safety Switch (normally open)
5960-2 Keys, Ignition
5982-1 Insulator Washer 2"
5982-2 Insulator Bushing
5984 Electric Contact Spring
6048
6054 Spline Coupler
6108 Cable
6109 Cable
6199 Transmission Spring Assy (RH)
6201 O-ring, seal
6206 Pressure Relief Valve
6207-8
6230-2 Belt Set
623 1 Belt, Transmission Drive 3/8" x 35 1/2"
6233-1 Pinion Gear
6235 Spring
6236
6240-1 Pulley,
6240-3 Pulley,
6242 Pulley,
6244 Pulley
6245 Pulley,
6245-1
6251-1 Belt
6340
6345
6346-2
6350 Engine Belt Tightener Arm
6430
6526 Intake Tube (6 1/2 x 2 1/2)
6543 Housig (10"Blower)
6569
6610 Thatcher Tine
6715 Anti Scalp Wheel
6732-1 Connecting Shaft
6732-3 Connecting Shaft
6840
6840-1 Support Arm Bushing (2-1/16)
7013
7017
7017-1
7020 Fuel Filter
7050-1 Dipstick, Gearbox
7108 Control Assy. Throttle & Choke
7201-1 Needle Bearing
7201-4 Inner Race (1 1/2")
7201-3 DU Bearing
7214 Control Rod L.H
7221 Spring, Compression (1/2 x 11 1/4)
7223-1 Spring. Compression
7226 Spring
7231 Belt
7231-1 Belt
7234 Belt, Blower (3VX280)
7235 Belt, Ground Drive
7237 Pulley, Engine (Flywheel Mount)
7238 Pulley, Blower Drive (4 1/4 /3V)
7239 Pulley, Blower (3-3/8 / 3V)
7240-1 Pulley, Jackshaft Drive (3.5")
7240-2 Speed up kit
7241-2 Pulley, Transmission Drive (3 1/4MV)
7245 Pulley
7245-1 Pulley, Idler (3/8 groove)
7246 Speedup Kit
7273 Jacksft (3/4 x 8 7/8)
7275 Universal Joint Tube Assy.
7285
7303 Break Band
7303-10 Clutch, Actuator Bolt
7306-10 Switch ( 235 Deg. 1/4-18 NPT)
7306-3 Temp Gauge
7306-4 Temp Sending Unit
7349-1
7349-2 Spring
7350-5
7350-6 Spring
7377 Plastic Washer (1 x .438 x .025)
7378 Pivot Bearing (7/16 x 9/16)
7380 Knuckle Joint
7395
7405 Pin, Transmission Lock
7409 Cable, Brake Control RH (20.5")
7411 Seal
7500 No Catcher Deflector kit
7530-3 Body Chute
7534 Catcher Handle Kit
7638
7775-1 Pin, Hitch
7775-2 Pin, Hitch
7940 Wiring Harness
7941-5 Circuit Breaker 7 amp
7942 Switch
7942-8 8 way connector, male
7948
7958-1 Plug kit
8011-1
8013 Muffler
8035 Tail Wheel & Tire Assy.
8037-1 Seal, Outer (1 3/4 x 1 1/8)
8037-2 Bearing Cone
8038-1 Spacer, Tail Wheel axle
8108-3 Cable
8108-4 Cable
8121 Throttle Control Cable Assy
8122-1 Cable, Choke
8130 Push Rod, Clutch Actuator
8230 Belt, Engine PTO
8243 Clutch, Idler pulley
8246 Speed up kit
8304 Brake Band
8368 PTO Belt Tightener
8677 Spring
8678 Spring Mount, Chute
8728 Machine Bushing (1/2" x 1 1/2")
8731 Belt
8736 Belt, Drive
8740 Bushing, Deck Pin
8742-1
8744
8768 Tire & Wheel (Caster Wheel)
8768-2 Seal, Reverse Lip
8769-8 Dust Cap, Deck Caster
8787 Knobs
8797 Clamps
8941 Circuit Breaker (30A) Auto Reset / Sealed
8942 2 Way Connector, Male
8960-2 Key, Ignition
9706-1 Spring
990314 Hydromotor seal kit
F012 3/8 - 16 Keps Nut
F013 3/8 - 16 Whiz - Locking Nuts
F017
F038 Bolt - 3/8 x 16 x 1
F062 Washer
F077 C-clip
F095
F114 5/16 - 18 x 5/8 SQH Set Screw
F132 Bolt, Hex (1/4-20 x 2 3/4)
F137 Bolt SHL 3/8 - 16 x 1/2 x 2
F139
F141
F142
F157 1/2 - 20 x 1 1/4 Wheel Lug Bolt
F191 3/8 x 1 1/2 x 3/16 Washer
F192 3/8 - 24 Self - Locking Nut
F194 Washer, 7/16 x 1 1/4 x 1/8
F200 Bolt, 7/16 - 20 x 3 Grade 8 Bolt
F221
F305 1/4 - 20 x 3/8 SH Cap Screw
P647
P648
SG004
SG014
SG018
SG030
Bill Roadman
The 5519 Actuator motor (12/24 volt) is selling new for about $120. I need one, but do not want to spend that much. Is your's new or used?
Bill
fwfd
The one have is new. Actually all the Walker parts are new.
They are on Ebay
www.fwfd.net should take you to me Ebay store.
Hargraves
I am looking for a walker muffler # 8013-9 If this is the one you have I will buy it
sethwilson
Do you still have any walker parts? if so i'm looking for the 5088-5 Air Cleaner draw latch. if you have it i would like to know how much you would sell it for and to ship it.
Thanks, Seth.
